-   -   How to tell which drive is port or starboard (https://www.offshoreonly.com/forums/drives-lower-units/290741-how-tell-drive-port-starboard.html)
s022mag 01-28-2013 12:09 AM
I pulled my TRS's couple months ago and can't remember which one went on which side. Is there a way to tell which is LH or RH?
Randy Nielsen 01-28-2013 12:28 AM
If you turn the input shaft the same direction your engine turns you can tell if you know which direction your props were turning, in or out.
c_deezy 01-28-2013 01:07 AM
Prop Shaft should be stamped on the end of one of them.
Mbam 01-28-2013 06:26 AM
As C_D says the prop shafts should be stamped on the end. Like Randy says turing the input shafts will tell you the rotation. If the input & output turn opposite = RH drive, the same = LH drive.
Most likely the LH drive is the port. That is the most common, with the props spinning out.
Do not get the props mixed up !!
GTOKILLER 01-28-2013 07:08 AM
Been there done that! almost ended up into a concrete sea wall while I was looking backwards! :poopoo: good thing it was at idle & I was 20 feet away.
Kings11 01-28-2013 10:58 AM
Lmao did that the first time I put the engines in the Velocity and wanted to do a shake down before a Poker Run.
Drove it right back up the trailer haha.
s022mag 01-28-2013 11:56 AM
I remember which prop goes on whcih side, the even number prop goes on the starboard and the odd number stamped on the prop goes on the port. So if I turn the input shafts the same direction then one should turn one direction and the other the opposite direction???
Also, back to sanding and painting the drives what's a good grit to start and finish with and how important is it to get all the old paint off?
dereknkathy 01-30-2013 05:27 PM
that is 30 year old aluminum that is not available new any more. don't go too crazy sanding them.
s022mag 01-30-2013 08:40 PM
Trust me when I want to do the min:lolhit:
