Advice on short Alpha 1 drives
Hello Guys
I am looking info and advice on setting up a new project. I will be using an Alpha 1 drive asm but want to find the shortest upper and lower boxes as possible. Any advise would be great. Cheers Mick |
either an Alpa ss or a tripple widgets deluxe. Be carefull with the deluxe though, if you top 88 mph there will be a flash of light and it will suddenly be yesterday's tomorrow. Though the truely troubling apsect is that you will find Micheal J Fox laying on the bow wearing nothing but a speedo.
Don't try to reinvent the wheel, get an SS rebuild it with the HD gear set & shim it properly, break it in nice and easy, change the oil every ten hours, and have fun boating
Originally Posted by Sonic30ss
(Post 3860176)
I am setting up a tunnel boat with a V8 sturn drive for curcuit racing. My aim is to get the engine mounted as low as possible. Do imco short lowers bolt up to alpha ss upper box ? |
(Post 3860176)
Originally Posted by sprink58
(Post 3860133)
The alpha ss has a shorter lower. I nelieve they talk about them on donzi.net or something like that. Its been a few years since I thought about them but it may be a cle? lower or people were using some kind of merc outboard lower to make ss clones or something. Not sure how an alpha is going to like surfacing, have you thought about a blackhawk? |
Originally Posted by phragle
(Post 3860372)
yeah thats the 88mph flux capacitor drive.
The alpha ss has a shorter lower. I nelieve they talk about them on donzi.net or something like that. Its been a few years since I thought about them but it may be a cle? lower or people were using some kind of merc outboard lower to make ss clones or something. Not sure how an alpha is going to like surfacing, have you thought about a blackhawk? Ok so the SS has a short lower only, I had believed it had a short upper ? I will look into a blackhawk. We have a couple of these boats running in Australia and they are using Alpha 1 becouse they are light and only need to put 600hp into the boats to get speed. |
The Alpha SS reduces the X dim by the upper housing being 2.5" shorter then a standard Alpha. The lower gearcase is a Mercury CLE offshore case. It is the upper NOT the lower that makes the height difference. The Alpha case is faster then the Bravo cases, smaller bullet.
Originally Posted by firefox1
(Post 3860436)
| All times are GMT -5. The time now is 07:27 PM. |
