-   -   Imco SCX-4 - info (https://www.offshoreonly.com/forums/drives-lower-units/291966-imco-scx-4-info.html)
AB69Z 02-22-2013 06:26 AM
Imco SCX-4 - info
Looking for an education on these drives
575cat 02-22-2013 08:56 AM
LIke ?
1 MAIDEN AMERICA 02-22-2013 10:48 AM
They're way bigger than a Bravo.
You have to change the helmet
You should install a HD gimbal ring
You have to add a through hull water pick up
You have to add a larger drive oil reservoir
It takes a #6 prop
You should have the lower trued
You have to trim certain styles of shift cables
You'll need all new tools for working on it
With twins you'll have to shorten the tie bar
You should safety wire the shower bolt to a gear cap bolt
Reports on strength look promising
I'm at 50 hours or so and a quick look at the gears shows as new.
offshorexcursion 02-22-2013 02:55 PM
It takes a #6 prop
Spot on!
offshorexcursion 02-22-2013 04:09 PM
In some cases you may want an extension box to help dial the boat in perfect.
Also might need to adjust the drive height/X-dimension up or down.
1 MAIDEN AMERICA 02-22-2013 04:54 PM
May as well add a blower since it's stronger and takes more HP to turn.
MarkDonzi 02-22-2013 08:59 PM
It takes a #6 prop
Mine just came in, I'm running Merc 600 SCI's what power are you running through yours?
KWright 02-23-2013 03:17 AM
Originally Posted by offshorexcursion (Post 3872866)
Spot on!
What he said! I have over 40 hrs on mine.
TheGladiator 02-23-2013 11:22 AM
I have a 39' at lip-ship for sale with a set...they are great!
Sonny Spectre 30 02-23-2013 05:38 PM
I have a set of 1" spacers for that drive if anyone needs them. 1/2 the cost of new. PM if interested.
SkiDoc 02-23-2013 07:57 PM
2 Attachment(s)
I've got a complete IMCO Extension box, Complete gimbal and steering for SCX for sale. Would be a great deal for someone. Would be able to bolt the boxes on and go. Pm if anyone needs this.
TRL505 02-23-2013 08:31 PM
Switching to #6's or -4's??
1 MAIDEN AMERICA 02-24-2013 05:39 AM
700hp 575's
SkiDoc 02-24-2013 06:51 AM
3 Attachment(s)
Not switching drives, just bought quad ram steering complete set up.... The boat does not need #6 weight in the transom.... The drives themselves will be kept, just everything in front of them. I've got some work to do.
MDGperformance 02-24-2013 10:15 AM
Do the -4 imco scx have a water pickup built into the case or you guys installing the external pickups for better water flow
KWright 02-24-2013 06:02 PM
1 Attachment(s)
Attachment 494516
External
KWright 02-24-2013 06:12 PM
1 Attachment(s)
Attachment 494517
And the drives all feed this one strainer that feeds both motors.
32hustlin 02-24-2013 06:48 PM
Is anybody picking up speed w these things vs bravos.
1 MAIDEN AMERICA 02-24-2013 07:38 PM
I picked up 1.5 MPH
1 MAIDEN AMERICA 02-24-2013 07:47 PM
The -4 has a water PU but IMCO said it's only good for drive shower water.
I had water pressure problems with my initial through hull setups so I ditched them and tried getting water from the drives only. As I started throttling to get on plane water pressure would climb. As soon as the boat started to nose over the water pressure dropped to 0 PSI.
I kept playing with the through hulls. The problem ended up being the Hardin SS raw water pumps. All I can see is that the impeller cavity is a bit smaller than on the plastic housings.
