-   -   Torco RTF (https://www.offshoreonly.com/forums/drives-lower-units/295905-torco-rtf.html)
MarkDonzi 05-06-2013 08:25 PM
Torco RTF
Hi Guys,
Wondering where the cheapest place to buy Torco Racing Tran Fluid.
Any suggestions?
Thanks, Mark
SkiDoc 05-07-2013 06:01 AM
No place is cheap. I've just bought mine through IMCO in 5 gallon pails. I believe they were about the same as everyone else.
PRIMECUT 05-07-2013 09:49 AM
Local speed shop should be able to take care of you ,ours gives us good case prices when we combine with a dozen cases of Brad Penn . this place is'nt bad either have a few buddys order from them
http://pitstopusa.com/i-7793245-torc...FaNhMgodLWEAPg
customryder 05-10-2013 08:15 PM
amazom 20 bucks a qt. dont know if thats the lowest..
07DominatorSS 05-13-2013 09:07 PM
Or you could get this...
http://www.amsoil.com/shop/by-produc...fluid-sae-10w/
Pwraddr 05-19-2013 07:15 PM
Originally Posted by 07DominatorSS (Post 3924909)
Not recommended by Imco.
weldcrane 05-19-2013 07:17 PM
i get mine here Wurlitzer Racing Products 1 800-982-9367 ask for jeff
drpete3 04-20-2014 08:19 AM
Mark where did you end up getting yours
07DominatorSS 04-20-2014 09:56 AM
[QUOTE=Pwraddr;3928407]Not recommended by Imco.[/
Recommended or not, as long as the fluid meets or exceeds the same spec, you can use it. After doing some more research, looks like this would be the equivalent..... I was wrong with my old previous post.
http://www.amsoil.com/shop/by-produc...?code=MTGQT-EA
Pwraddr 04-20-2014 10:01 AM
Originally Posted by 07DominatorSS (Post 4109380)
Doesn't matter if its recommended or not. It is the Amsoil equivalent fluid.
It does if you want to use the recommended fluid from Imco.
