trim height question
was hoping someone could help with a suggestion on my trim height . had to replace trim senders and need an idea of distance to set full up on throttle trim switch. inches from ram bolt to ram bolt. it for my 08 donzi zr27, it does have twin steps in the hull , can get any other measurement needed thanks
We adjusted it based on a different measurement as found here...
http://www.mercstuff.com/trim_limit.htm
hopefully there is no difference in the measurements.
Anyone have any knowledge on this?
Using those instructions, I would question if they are referencing their adjustment height to an R/MR/ALPHA ONE/Alpha One Gen 2/Bravo drive, etc. etc. as they have different trim adjustment heights which is typically measured from front anchor point to rear anchor point centerlines.
The instructions didn't seem to clarify/reference what drive model they were setting up/adjusting.
