-   -   Saddle v Top Mount Tie Bar (https://www.offshoreonly.com/forums/drives-lower-units/300245-saddle-v-top-mount-tie-bar.html)
glboatdriver 07-23-2013 06:47 PM
Want/need a tie bar on my Formula 330SS w/ 496 Mags.
Can you enlighten me on the differences / advantages of these two mounting types; saddle v top of gear case?
kvogt 07-24-2013 10:17 AM
Either are good. Some run both cause it looks cool. If one has a clearance problem run the other one. Check for clearance with the drives all the way up under the swim platform.
glboatdriver 07-24-2013 11:15 PM
Thanks kvogt,
I'm new to twins and had no clue. I appreciate the input. Probably gonna go with an Eddie Marine or equivalent saddle mount this fall.
