-   -   bravo install gaskets ?? (https://www.offshoreonly.com/forums/drives-lower-units/301729-bravo-install-gaskets.html)
Andrew 19 08-20-2013 06:05 AM
Time to install outdrive. All "O" rings in place. Can't find part # for gasket that keeps water out of driveshaft tube, (snout). This gasket keeps driveshaft bellows free of water. It's been a long 2 years.
Thanks for all the help thus far.
P.T.L. Rory
seafordguy 08-20-2013 06:22 AM
I'm not sure what gasket you are talking about. The bellows just fits around the transom assembly and is held on with a hose clamp and in the rear it slides into the bell housing and you pound in the ring/sleeve from inside. The drive itself just mates directly against the bell housing and yo u tighten down the 6 bolts
motor 08-20-2013 06:28 AM
On a bravo ,there is no additional seal at snout .Drive seals against exposed portion of u-joint bellows
Andrew 19 08-20-2013 05:25 PM
Thank You !!
