-   -   Grenaded a TRS, Possible Causes? (https://www.offshoreonly.com/forums/drives-lower-units/302345-grenaded-trs-possible-causes.html)
502ss 09-01-2013 03:31 PM
Was going across the lake today about 70 and grenaded a drive. The water was calm and we were just cruising. Any idea what would cause this? The gears looked fine the beginning of the season and she only has 20 hours on her this year. Trying to understand why it broke the carrier cap, was it from vibration or did the shaft move?
I haven't pulled the drive yet so just wondering initial thoughts....
http://i69.photobucket.com/albums/i4...ps7afff699.jpg
http://i69.photobucket.com/albums/i4...psa23d7332.jpg
http://i69.photobucket.com/albums/i4...psf6a14816.jpg
MILD THUNDER 09-01-2013 07:01 PM
Had the exact same thing happen to a trs. Blew the upper and busted the rear cover. Never knew why that happened. Usually the RH lower is what lets go from too much power. But the upper? Idk, low fluid level ?
smokin' gun 09-01-2013 07:24 PM
jim i have no idea why .mine broke just ideling in a no wake zone .but either way i have a complete upper
for u cheep let me know
vintage chromoly 09-01-2013 08:05 PM
The lube level looks slightly low but it's still above the bottom on he pinion gear.
vintage chromoly 09-01-2013 08:06 PM
That drive looks old and the gear lube looks black. When was it changed last?
Could be plain old fatigue.
502ss 09-01-2013 08:19 PM
Fluid was changed this spring, drive is old but was checked in the spring and looked okay. Fluid level was okay except for what leaked out from the broken front cap!
Strange!
el indio 09-02-2013 01:32 PM
TRS problems???????????? mel riggs @ riggs marine. he has gears and housings..quality operation..............920 872 2728........
