What is the best drive shower for this setup?
1 Attachment(s)
[ATTACH=CONFIG]508524[/ATTACH]
Bravo X drive with Latham steering. Thanks Tim |
Latham make a top cap set up for that maybe?
Livorsi sells one that works like a Simrek, but IMO has way better water pick ups. It will only work on a std length drive as I found out. The only thing I would check is that since it has 2 water pick ups, is that it has a wall between they so they are not fighting each other. I corrected that issue with my Simreks.
Smith what did u do to correct that?
I like the ones made by Wags Engineering... not sure how they will work with your steering set up though.
I found out I just have to buy the hoses from Latham, top caps are already threaded for the showers. Thanks
What did you do to fix? Got any pics?
Originally Posted by Smitty
(Post 4004140)
| All times are GMT -5. The time now is 05:01 AM. |
