-   -   XR upper gear set inspection (https://www.offshoreonly.com/forums/drives-lower-units/303805-xr-upper-gear-set-inspection.html)
sport 10-05-2013 07:06 AM
I have about 100 hours on my XR that has had about 750 hp in front of it and I what to inspect the upper gear set, can I remove the upper rear cover that the steering rams hook to and see the gear set? I have change the oil about ever 15 hours and have had no metal in the oil or on the magnets but I still would like to take a look.
Thanks John
Griff 10-05-2013 02:19 PM
No. You will have to completely take the drive apart to see the gears.
motor 10-05-2013 05:02 PM
You can inspect the driven gears and get a good idea of condition by just pulling back cover of upper
Griff 10-06-2013 12:04 AM
You can see them, I guess, but really can't see them well enough to be able inspect the wear patterns and evaluate whether there might be problem approaching.
1 MAIDEN AMERICA 10-06-2013 08:47 AM
At 100 hours with 700HP, REPLACE them. At 105 hours I broke a set. 1 tooth came off, seized the drive, broke the coupler shaft in 3 pieces and twisted the heck out of the coupler. The rest of the teeth looked about new. Absolutely NO pitting and just a slight shine. You can sell the used gears to recoup some money.
