-   -   Bravo one repair (https://www.offshoreonly.com/forums/drives-lower-units/304851-bravo-one-repair.html)
AddictedtoHp 10-31-2013 09:40 PM
Bravo one repair
Has anyone removed there bravo one gears and replaced them with a set out of another bravo one. Have a mechanical and cosmetic issue with bravo drive and looking to remove contents from case and install in alternate bravo one case. It does not look complicated, best I can tell it's not calling for any special tools. As I understand it, it depends on year make model of drive.
I've popped the top on both drive's I just can not bring myself to pull the trigger on attempting this without some input. At this point the upper portion is all that is of concern.
The way this is set up, using a spanner wrench I would remove the over sized nut, remove top cap, remove back cap. disconnect shifter mech. pull shifter pin, pull front drive shaft and gear assembly, and pull the main gears out of center. change gasket's seal's etc. and reassemble back into other drive case. Am I missing something here or is it that easy.
Thanks.
AddictedtoHp 11-03-2013 12:25 PM
ttt
Tinkerer 11-03-2013 04:45 PM
There are special tools needed. Everything has to be shimmed properly,.
Mr Gadgets 11-03-2013 11:31 PM
You can swap the gears with minimal tools, but for proper setup there is more to the process. The older drives had shim sizes stamped on the cases. But with the newer thick floored gears, Merc requires the shimming process be measured to get the proper gear lash.
Hope that helps.
Dick
Sick Stinger 11-09-2013 03:29 PM
I have the tools if you need them. Ill ship them out to you with a manual when done shoot them back no rush on my end if you want
Mike
smokin' gun 11-13-2013 06:28 AM
mike i do believe this is the guy that stiffed you on the drive .new screen name lives in ohio ???
AddictedtoHp 11-13-2013 08:06 AM
Thanks mike got someone locally to show me an not sure what the other comment is about. But thanks for offer
smokin' gun 11-13-2013 08:48 AM
Funny 5 posts new member. And same ip addy as someone else here.
mike tkach 11-13-2013 09:40 AM
one in the same but im sure that both will be banned before the day is over.:banned:
mike tkach 11-13-2013 09:43 AM
mr debo,you can run but you can not hide.as i said on a different thread,the oso possie will find you,and we have.
