bmax lower design? good or ok?
anyone have any experience with the bmax built lower unit case? is it as efficient as the imco sc lower or max machine workx lower? I will be replacing an imco sc lower with it, possibly! any input on its design, or speed lose or gain? thanks
IMO the bmax lower is no better then a imco SC lower. They both use the same xr gears. If your looking for better hydrodynamics the imco has been the benchmark to compare to.
Now the Bmax upper has larger gears and some love them and say they are bulletproof and some hate them. I have a few friends and OSO members who used to rave about the bmax till thier own broke. Now they are to embarresed to post after being a bmax cheerleader. |
Give John at Bmax a call he's changed several of the parts that go into today's Bmax design. He can tell you about the differences over the years.
Originally Posted by offshorexcursion
(Post 4041573)
I have a 24 ft HTM also ,and had a Bmax 1,30 (normal drive height) last year with a 800 hp BBC blower engine ,off course the blower engine went boom after some hours ,it went 96 mph on the few runs I did ,so I removed the blower engine ,and bought a 500 Bulldog to be on the water again ,I also removed the Bmax and now run a Bravo X drive at 80 mph .
I also going to a new engine next year with about 1000-1100 hp ( hopefully) and thinking about using the Bmax again ,or buying a SCX unit ...and use a SC lower I can,t speak about he hydrodynamics of the Bmax lower cause I did not had the time to use other drives or lowers with the same engine . |
Maybe call WCM and see if they have ever blue printed a BMAX???
http://www.offshoreonly.com/classifi...o38596-en.html
Claims the fastest lower on the market.................. |
| All times are GMT -5. The time now is 04:40 AM. |
