What fitting do I need for my remote oil bottle?
3 Attachment(s)
So my original Bravo Transom assembly has a brass nipple that the remote oil bottle connects to and I just got a newer transom assembly and it has a plastic fitting on it. The line from the remote oil bottle is not big enough to fit over the plastic fitting so I think I must be missing something? Or can I put the fitting from the old transom assembly on the new transom assembly?
[ATTACH=CONFIG]515440[/ATTACH][ATTACH=CONFIG]515441[/ATTACH][ATTACH=CONFIG]515442[/ATTACH] |
You need part # 22-861163. Any Mercruiser dealer should have it. Retail on it is $7.90. Or I can sell you one cheaper if you cant get it locally- Jim
Originally Posted by jray1010
(Post 4049998)
Also just be aware that it appears from the photo that you are also missing the needed O-rings. See item numbers 2 and 3,
http://www.mercruiserparts.com/Show_...OIR+COMPONENTS |
I will take care of you Jason. I think I have one of those here.
Originally Posted by Baja226sport
(Post 4050635)
Paul I keep a couple in my truck let me know if you need any.
Question: if you have an older assembly with the brass fitting, can it be replaced with the new plastic part? I would think the brass setup would be the way to go. Thx
Originally Posted by Borgie
(Post 4050999)
http://www.boatfix.com/merc/Bullet/98/98_12.pdf |
| All times are GMT -5. The time now is 08:07 AM. |
