-   -   Verify Bravo (https://www.offshoreonly.com/forums/drives-lower-units/307432-verify-bravo.html)
jvthundercat 01-14-2014 02:16 PM
Verify Bravo
Which Bravo One is this?
It says 1:36 ratio. But, to me it looks like only a 1" shaft, maybe I am wrong.
With that nose cone, it's not a standard One.
http://i1205.photobucket.com/albums/...psca002b80.jpg
Fenderjack 01-14-2014 02:31 PM
Looks like it has had a nose cone added.
John jr
jvthundercat 01-14-2014 02:40 PM
Ok, he is going to measure the shaft when he gets home.
He put a new Teague TCM Platinum XR good for 800hp on it and has the same prop hub. So it should be 1.25" shaft then. Correct?
Unlimited jd 01-14-2014 03:46 PM
That's an old standard bravo with a poor nose cone job
pinball 01-14-2014 04:01 PM
i agree
Mr Gadgets 01-14-2014 04:37 PM
One way to tell the ratio, spin the input shaft until the propshaft turns one turn. Mark the yoke and the propshaft and spin it.. If you spin it enough times to have the propshaft turn 10 times. The input shaft would turn 13.6 times if it is a 1.36.....
This looks like an "Assembled from spare parts" type of drive.
Hope that helps.
Dick
jvthundercat 01-14-2014 04:42 PM
Thanks guys. I was looking for some Bravo's to go through. He called back and it's a 1" shaft.
Shifter and top end are blown out of it, lower maybe good, but would have to see first hand on the weld job.
