TRS shaft coupler - what's the coil metal for and is this broken?
The coupler that connects the upper and lower shaft in a TRS has this metal round stock wrapped around it. Whats the purpose of it and I assume it's supposed to be connected on both ends and not broken like in the photo? Ugh!!
Thanks guys! I will weld it so it's attached at both ends. The scratches are from a pair of plyers I used to hold the lower shaft so I could break the nut loose.
So I didn't pay attention to its orientation when I took it out! Does it matter which direction it goes in?
Offshoreonly Advertiser
Can go in either way
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
