-   -   TRS Gear question (https://www.offshoreonly.com/forums/drives-lower-units/314938-trs-gear-question.html)
ctuck0659 07-09-2014 09:35 AM
TRS Gear question
Do pinion gear sets form a wear pattern that requires both to be replaced as a set? I chipped a couple of teeth on a prop-shaft gear. The vertical pinion gear looks perfect- do I need to replace it also?
crazy canuck 07-09-2014 09:17 PM
Always replace gears in a set .
