-   -   SSM III orings? (https://www.offshoreonly.com/forums/drives-lower-units/316175-ssm-iii-orings.html)
wieland77 07-31-2014 03:43 PM
SSM III orings?
I bought a set of used SSM 3 drives and the oring for the oil res check valve and the large oring for the bellows seal didnt come with the drives. Anyone have an idea what the parts #'s are for these? there are the only 2 seals on the drive correct?
waterbum 08-01-2014 03:00 PM
I called Gaylen at Speedmasters, Inc. in Florida when I needed SSM III parts. He'll set you up with anything you will need and answer any question you may have. Very helpful.
wieland77 08-01-2014 03:14 PM
Will do, thanks!
