Prop depth difference between Bravo 1 and Bravo 2? >
Old 10-13-2014 | 11:32 AM
Default Prop depth difference between Bravo 1 and Bravo 2?
How much deeper does the prop sit on the Bravo 2 drive compared to the Barvo 1.?
Looked high and low online and cant find the size dimensions for both.
HTRDLNCN is offline
Old 10-13-2014 | 12:58 PM
What is a Bravo 2. Don't remember ever hearing of it.
kevlar382 is offline
Old 10-13-2014 | 01:03 PM
longer lower for diesels, for a larger diameter prop.
phragle is offline
Old 10-13-2014 | 08:17 PM
just a longer version of a bravo one..
Just need to know how much longer..having hard time finding that info..
HTRDLNCN is offline
Old 10-13-2014 | 08:21 PM
BUP
bravo II can swing a 20 diameter prop bravo one can not. The lower is longer depth but the upper is basically the same. Bearing carrier for a Bravo II takes a different tool to take out compared to the bravo I.
BUP is offline
Old 10-13-2014 | 08:29 PM
BUP
forgot the Bravo II uses a 19 spline prop shaft and Bravo I uses a 15 spline propshaft.
if I recall correctly its exactly right at 4 inches longer bravo II compared to Bravo I.
Also Bravo II were and still used on a lot of gas apps.
BUP is offline
Old 10-14-2014 | 08:17 AM
So prop sits 4" deeper?
Thanks BUP!!
HTRDLNCN is offline
