Hydraulic steering ram leaking???
I've got one last trip out on the boat coming this weekend and I noticed that my port side ram for the hydraulic steering is leaking. My fluid reservoir is low so I figure I better add some just not sure what it takes. Also can the ram be rebuilt or does it need to be replaced. Or should I not boat with it leaking at all until rebuilt/replaced?
I would find a local hydraulic shop they should be able to rebuild the ram. I went thought the same thing last year and it was around $200 per ram here in north Texas.
Shouldn't be very hard to rebuild. Easier than a shock, no shim stacks to deal with, just o-rings and seals.
Fill reservoir and go boating.
The ram can be rebuilt/resealed by the manufacturer or most likely locally. |
Originally Posted by Griff
(Post 4207114)
The ram can be rebuilt/resealed by the manufacturer or most likely locally. Funny how I noticed it must not be real bad. I lowered the drives to get the boat to fit in storage so gravity must be helping. Then I wondered why I didnt see a leak when it was in the water? Must be enough water pressure 12in down that doesn't allow it out. |
I took mine to a local heavy equipment / agricultural cylinder shop.
Very basic prcedure to rebuild a hydraulic cylinder. 75 bucks each. New seals and o-rings and a test when done. Hardin wanted considerably more. |
Just noticed you are in Ohio. The guy I used is just north of Ashland.
Small mom and pop shop in an old barn but they know their stuff. |
What kind of fluid should I use?
Originally Posted by s022mag
(Post 4207160)
Thats the answer I like. But will probably look around to see who can rebuild it. What kind of fluid?
(Post 4207197)
| All times are GMT -5. The time now is 02:13 PM. |
