-   -   86 242 Bravo drive (https://www.offshoreonly.com/forums/drives-lower-units/320190-86-242-bravo-drive.html)
79formula 11-16-2014 01:14 PM
86 242 Bravo drive
I just upgraded to an 86 242. I checked it out and got it home. The swivel pins are toast. Tons of play in the upper. It looks as if the gimbal ring is shot too. To change the bushings, pin, seal, and ring, are they the same for all Bravos? My transom tag # is 0L816884, the drive is much newer than the boat. Thanks
79formula 11-16-2014 01:49 PM
I am doing research right now. I am confused as to which drive I have. The drive says "High Performance" on it, has water pick ups on both the side and bottom, and the serial is0L474517. I am also seeing standard bravo, magnum bravo, and hp transom assemblys. What is the difference?
Jonesyfxr 11-16-2014 05:00 PM
Call Mercruiser. They helped me out when I was looking for a new engine harness.
