Black Hawk Drives
SubscribeAnyone know if a Black Hawk Drive is stronger or weaker than an Alpha 1 Gen 2 ? Is it faster... Slower ... Planes better or worse... Why did they quit making them...
Chris
Chris
scarabman
close
- Join DateNov 2002
- LocationTR, NJ
Liked:227 Times in 117 Posts
The Blackhawk is a surfacing/semi surfacing counter rotating duo-prop drive. It shares quite a few internals with Bravo based drives and therefore is essentially as strong, or weak, if you prefer, as a Bravo. The biggest weak point was the case themselves and that is where there were quite a few failures. The main reason they stopped making them, was application based, as there were very few boats that were accommodating to the design/application. When they worked, they worked quite well, when they didnt, they didnt. Where they tended to work well was on boats size appropriate, with substantial natural rocker. Ultimately there was not enough of a market.
I have no idea what kind of boat you are thinking of swapping an Alpha to a Blackhawk, but it is probably pretty unlikely that it would yield positive results, unless you have one of the forementioned type hulls.
scarabman
close
- Join DateNov 2002
- LocationTR, NJ
Quote:
Indeed they did, but the P-29 hull was intended to be application specific for the Blackhawk. Put them on standard 29 and its a different ballgame. The boat to look at for Alpha/Bravo and Blackhawk differences might be the Donzi "Blackhawk" and standard versions as I dont recall any substantial changes in the hull from one app to the other?Originally Posted by nova26
The P-29 worked well with the Blackhawks.
