-   -   Bravo XR Upgrade (https://www.offshoreonly.com/forums/drives-lower-units/320589-bravo-xr-upgrade.html)
salesdeity 11-28-2014 09:13 AM
Bravo XR Upgrade
My winter project is to upgrade my Bravo XR drive on my 2004 29' Fever 525. Boat runs 78 mph on the limiter with a stock B1 26" and no problems with getting on plane or blowout. I want to upgrade my XR LWP 1.5 ratio to add reliability and make future power upgrades possible too.
Wanted to see if anyone swapped out their XR on their Fountain or similar sized boat with an IMCO or Arneson. Which IMCO combination? Did you use a shortie on the IMCO or keep the XR lower? What were the results?
Thanks!
MarkDonzi 11-28-2014 03:28 PM
I changed my XR Uppers to IMCO SCX Uppers 2 years ago, about 100 hrs and no problems. First 50 hours with twin Merc 600SCI's on a Donzi 38ZR.Second fifty hours upgraded power to 850 a side and still no issues. XR uppers would last anywhere from 10 to 50 hours on original setup.
Relaxing 11-28-2014 07:56 PM
What he said
salesdeity 11-29-2014 03:53 PM
Thanks for the responses. Should I expect any loss of speed with the SCX uppers? Do I just reuse my XR lowers or is there a compelling reason to go to the SC lowers?
T-Mone 12-20-2014 07:48 AM
scx uppers an use sc lower works well
MDGperformance 12-20-2014 09:05 AM
with 525 hp a scx upper with xr lower should work great probably loose 1-2 mph turning a bigger set of gears
GAZ 01-03-2015 07:12 PM
If you have single engine 29 I would consider SCX Upper and SCX lower. I think it's worth the couple mph for the peace of mind of not blowing up a drive in mid season and having to baby it.
