-   -   oil level #3 (https://www.offshoreonly.com/forums/drives-lower-units/321303-oil-level-3-a.html)
weldcrane 12-21-2014 06:44 AM
oil level #3
what is the proper way to fill #3 drives? thanks
Unlimited jd 12-21-2014 07:03 AM
Same as a bravo, pump in through the bottom until it comes out at the top. I just fill to the vent in mine, don't put any in the expansion reservoir in the transom assembly
Unlimited jd 12-21-2014 07:04 AM
Btw they take 2.5 GALLONS of fluid each
weldcrane 12-21-2014 06:26 PM
It will expand enough to show in the site glass on the inner transom assembly ?
MILD THUNDER 12-21-2014 06:31 PM
Supposed to.
This year, I plan to add a bravo style reservoir to mine. I am going to put a nipple fitting on the inner transom plate, where the current breather vent is, and plumb it to the reservoir bottle. I am sick of guessing if i have enough oil in the drives or not.
weldcrane 12-21-2014 06:42 PM
You have a sight glass on the transom assembly that you can see ?
Unlimited jd 12-21-2014 08:15 PM
I do but I don't put any fluid in there. Read too many times about it puking out. I just crack the top plug and make sure clean fluid starts to come out once a week.
ricardo mann 12-22-2014 06:27 PM
1 Attachment(s)
[ATTACH=CONFIG]534741[/ATTACH] i have res on 3 drive and i also have retro fitted res on tail stocks
