-   -   prop shaft height on a straight V hull (https://www.offshoreonly.com/forums/drives-lower-units/322407-prop-shaft-height-straight-v-hull.html)
finishline 01-24-2015 06:07 PM
I have a 31 sutphen im working with has prop shaft 6 3/4 below bottom of the boat with standard bravos now what are others running on there straight v hulls. Im going with 12'' extension boxes and -2 lowers now is my opportunity to move the x up since everything is coming off the transom anyway.
Looking for tried and true instead of theory here.
pstorti 01-24-2015 06:16 PM
Mine are 9" below the bottom, no steps but the transom has a notch. Boat runs 58. Not sure if that helps or not. I actually added 1.5" spacers to bring them down because I couldn't get any bow lift out of the trim before I added them.
Unlimited jd 01-24-2015 07:08 PM
Twin engine sutphens run pretty well with them a little deeper than most other straight vee hulls. I've noticed they run real high out of the water, the lifting strakes pop them way up. If I get a chance a customer has the old f2 race boat, with bravos on boxes I can measure the propshaft height next time I see it.
I'CE 01-25-2015 12:41 AM
finishline: is she BBC or SBC and IMO what your doing is changing the X __ what year is she and tell us about your power, gear and wheels. __ Did you ask Ritchie by chance? He prob. has the best tried and true answer for you.
smiklos@sunprint 01-25-2015 08:38 AM
I think the F2 31" Sutphen 2..25 below bottom on 12" setback.
Steve
finishline 01-25-2015 10:19 AM
1991 31'. twin bbc 36" center on the drive centers 500hp each side. Bravo one drives 6 3/4 deep 27-28p b1 props. This is my current set up as it sits right now. I will be going to a standard 12" box and -2 imco sc drives.
