Bravo 1 LowWater conversion?
Hey everyone I am tired of sucking up sand when I am in Destin. So much sand it will clog the hose. I have a bravo1 with LWP only. Can I drill side water pickup holes in this lower and solve my problem? If I can how could I plug the slits in the front of the unit?
Trade the case. send it and I can put your parts in one that I have.
Hey Jerry, Thanks for the response how much would it run me for you to do that? What would the turn around be? I tried to PM you said you are out of space.
How do I send it to you?
So $800 and you keep my current case? I was hoping to get a fix to my problem for like $100 bucks. Swap for a used case or get a sea strainer or drill my current case.
what if you got something like an old TRS transom pick up? or does the bravo want the water flow through it for drive cooling?
| All times are GMT -5. The time now is 05:13 PM. |
