-   -   Bravo One Lower Shift Cable Tool (https://www.offshoreonly.com/forums/drives-lower-units/325874-bravo-one-lower-shift-cable-tool.html)
underpsi68 05-04-2015 11:16 PM
Can someone tell me the thickness of the plate that goes on the lower unit to adjust the shift cable with the drive off? I figured I can make one cheap.
BUP 05-05-2015 11:00 AM
Such an easy tool to buy even Sierra has them for cheap. Just saying
underpsi68 05-05-2015 09:29 PM
I'm not sure if we are talking about the same tool. The tool I'm taking about is just a plate the the cable slides into a slot on the outside of the transome. Not the tool that is used in the engine bay, that one I have.
BUP 05-06-2015 10:03 AM
I have worked on a boat or 2 in my day. I think I am on the same page as you. if I am following along correctly here is your help and I seen them for brand new 25 bucks as well. I would nt even turn on my power drill or power saw to cut a hunk of metal for something I can buy under 40 bucks. Just saying. and just messin with you.
http://www.amazon.com/Sierra-Shift-A.../dp/B000N9OW9S
also my cost is under that to for brand new and I am talking about the 25 bucks. Like I said a cheap tool to buy and never leave home to get it.
underpsi68 05-06-2015 11:18 AM
John I already have the tool to adjust the cable on the engine.. I have this one.http://www.ebay.com/itm/OEM-MerCruis...835d2c&vxp=mtr
I was just looking for the plate thickness of the bottom plate in your link. I have scrap metal in my basement. It wouldn't take much to run a sazall blade down a piece of metal, just to hold the cable in place. It looks like it is 1/8"thick..
Thanks for the link
BUP 05-06-2015 11:36 AM
I know that's why I post the link and I was really just messing with you. If you want I can measure it later and post.. I have a couple in my garage and some still in the package. Post back if you want me to measure it later.
underpsi68 05-06-2015 12:03 PM
John if you wouldn't mind could you post the thickness of that plate? I don't mind buying tools but this is just a plate I know I have sitting in my basement lol. I just bought an alignment tool, gimble bearing installer, bellows tool, water inlet tool, shifter adjuster. I think I have more coming but don't remember lol. Problem is I will hopefully only use these tools once. :)
I can't gauge your kidding in your posts but the just messing with you helps. On the phone talking to you was a little easier.lol
seafordguy 05-06-2015 01:06 PM
I have used a paint stirrer with a slit cut in it before. Total Cost - Free.......
BUP 05-07-2015 12:40 PM
1/4
underpsi68 05-07-2015 05:49 PM
Thanks John! After all this work I want it right. Lol
