Speedy 2's replacement options?
I want to buy this fountain but it has speedy 2's and engines that produce 1300hp total. Obviously I would like to have it on the water and working for longer than an hour. I know TRS's are pretty much a direct bolt on swap but are there any others that can handle this power somewhat reliably? Yes, I already messaged Biggis for his options of some Konrads. Just don't know if spending that kind of money on this boat would be really worth it. It's a 83 10 meter btw.
Is that 650 a side?Speedy 2's can handle that. Just not many options on props. TRS is a stepbackwards IMHO they are non surfacing props and run deeper.
The real issue is simply be easy getting on plane. Wannabe |
Originally Posted by wannabe
(Post 4303840)
Make sure you use your tabs. i do not know that hull and how hard it is to plane.
The SSM2 uses a TRS upper btw. |
(Post 4303926)
Parts are out there but limited. 650HP on a 10M Fountain should live if you throttle it well and don't try to beat it out of the hole. There were many 10M Fountains built with #2's from the factory. There is a set of Konrads in the swap section for 13K. Bolt them on and go no issues.
Originally Posted by CIG3
(Post 4304263)
I would run the boat with the #2's and buy some trs drives as spares . U can always put a 2 inch spacer in and get back to the #2 depth if the trs are to high. FYI I had a 85 10 meter trs boat (no spacer) that orginally had 2's and I also had a 88 10 meter trs boat.
Originally Posted by TomFTM
(Post 4304377)
Originally Posted by dereknkathy
(Post 4304401)
2's are deeper in the water than trs? i thought nothing (except tr's) were deeper than trs's. heck, a bravo 2 is only 0.3 inches longer than a trs.
Originally Posted by Rookie
(Post 4304447)
Yes, #2's are deeper than TRS. He will actually raise his X going to a TRS and maybe get some speed out of it. (That's just funny reading it!)
Thats what I would do.
| All times are GMT -5. The time now is 08:53 AM. |
