-   -   nose cone repair (https://www.offshoreonly.com/forums/drives-lower-units/327056-nose-cone-repair.html)
35fountain 06-07-2015 08:29 AM
nose cone repair
Hi everyone, I recently lost a chunk of the putty, filler that was installed on my drive when they installed my nose cones. I sanded the area down to bare metal and used marine tex as a filler. The stuff worked great but I can;t seem to get it perfectly smooth. I had to use a sander with this stuff. Is there another type of filler, putty that I can put over the top of this to fill in some spots. Something that is easier to smooth out by hand
Rattlesnake Jake 06-07-2015 09:22 AM
All metal is what I used.
SB 06-07-2015 09:38 AM
x 2.
It sanded smooth just fine after it dried when mounting the cone.
indysupra 06-07-2015 09:47 AM
What epoxy did you guys use to adhere it to the lower.
35fountain 06-07-2015 09:55 AM
Only a piece of the old putty came out. I am not installing new cones. I already fixed it with marine tex. That stuff dries like steel. What can i use to finish it ..? and make it smooth with no uneven spots
SB 06-07-2015 09:56 AM
We both used All Metal.
The confusion was that we didn't answer your first question.
CIG3 06-08-2015 10:13 AM
You can use marine tex as well. That is what Hydromotive used to give you with their kit. Worked well more me.
35fountain 06-08-2015 01:05 PM
dereknkathy 06-08-2015 09:15 PM
just use a right angle grinder-sander to rough shape it before trying to worry about smooth finish. otherwise you will be sanding all day...
ThisIsLivin 06-11-2015 07:34 AM
+1, That stuff is harder than the aluminum case, be careful finishing.
