-   -   Considering replacing TRSs w/Bravo XRs or Konrads 540 PRSs? (https://www.offshoreonly.com/forums/drives-lower-units/327472-considering-replacing-trss-w-bravo-xrs-konrads-540-prss.html)
OTSrange 06-18-2015 12:19 AM
I have a Cigarette Cafe Racer that currently has TRSs, and I'm doing a big reno on it. Not big power - haven't dynoed them, but probably 450-500 max. I'm just a mild, 49 yr old guy wanting a great 50 MPH cruiser with a 65 top end. Not going to pound her hard. It is in the budget and I'm strongly considering changing the TRSs out to Bravo XRs and getting rid of the trannys. Primary purpose is increased reliability, simplicity, serviceability, and enhanced resale value. Don't need to go crazy with Imcos or the likes. Increased speed is not the driving force (although I'm sure the higher XRs plus the absence of the tranny weight will add some MPHs). Engines/trannys are now out of the boat, transom is stripped. The transom is rotted and being replaced, so recutting the trans assembly holes and changing the X dimension at this point, is not a huge deal. Moving the engines back a few inches is also very doable.
I keep reading so many different opinions on the XRs. Some say they're inherently weak, others seem to really like them. With this relatively little HP, I don't know that it would matter. Considered going with Konrads (about the same overall conversion price), but then I still have the BW trannys to maintain and drain HP & speed. Does anyone have experience with converting to either XRs or Konrads on a Cafe Racer (or similar size/weight boat - 35', 11K lbs fueled)? If so, were you happy with the end result? Problems, issues? Input would be appreciated.
MILD THUNDER 06-18-2015 06:09 AM
You'll probably get more insight in the "cigarette" section here. But, I can say, its gonna take quite a bit more than 450HP per side to hit 75mph in a Cafe.
BDiggity 06-18-2015 08:08 AM
i have hawk 525's with trs & can hit 71-72 according to phone gps app. but my 525's have been worked over some with 250 blowers & 1050 dominator.
im also doing a major rehaul & have been trying to decide if i should dump the trs for something else, but also dont want $30k in drives on this thing. interested to see in which direction you go.
F-2 Speedy 06-18-2015 08:16 AM
I would leave the tranny's in it ( COG ) wont change and recut it for some #3's
donzi matt 06-18-2015 10:05 AM
Most 420 hp cafe's with TRS drives and transmissions ran around 63-64mph. My cafe with 496HO's (425 hp) and bravo's, with a raised X dimension spec'd by Lip-Ship runs 67-68mph. I may squeek some more out of it running on fumes, but I doubt there is much left. The boat drives like a dream but does blow the props out planing, but nothing bad enough to be annoying. The engine compartment is huge in the boat now and it is a dream to work on. Coming from my 311 Formula I used to dread doing anything under the hatch, on this boat it is actually a great place to hide out. I fantasize about running 75-80 but doing so is going to take big money, big power, and I will probably lose a significant amount of reliability and "turn key" boating.
OTSrange 06-18-2015 10:20 AM
Thanks Donzi - that's helpful. Guess I overstated my speed expectations (I revised it down to 65), but as top end is not really what I'm after, that's fine with me.
And if I'm going to leave the trannys in, I think Konrads would be the way to go.
Rik 06-18-2015 11:32 AM
If you guys are contemplating $30K then an extra 10 would get your speed and then some. Espically over a TRS drive, or TRS copy.
OTSrange 06-18-2015 11:53 AM
Yeah, I won't be spending $30K on them, so Arnes are def out. Great stuff, but way more than I need.
But now after having a lengthy conversation with George at All American Drive, he is strongly suggesting that I go with XZs, not XRs. Said with less than 550 HP, the helical XZ gears will wear and perform better than the straight cut XRs. Of course he'll sell me either, but says that I am not only wasting money on the Rs, but will also get better reliability from the Zs. And he'll warranty them for 2 years. Thoughts?
kaama82 06-18-2015 02:41 PM
I also agree with George. The XZ gears are easier to get and wear is better with less h.p. My drives are XZ gears with 525sc in front of them. No problems.
OTSrange 06-18-2015 05:57 PM
Thanks kaama - that's good to know. I've decided to go with XZs and get the HP transom assemblies. Could go with the standard gimbals, but this way, if I sell the boat and anybody wants to up the power ante', they can drop in XR gears and they're good to go.
Soooooo.....with that decision made - anybody want a set of gently used (and just repainted & stickered) TRSs, trans asmblys and 2 BAM Cyborg trannys? :D Will be lookin to deal!
