-   -   need merc #6 drive addvice (https://www.offshoreonly.com/forums/drives-lower-units/328000-need-merc-6-drive-addvice.html)
Thebossbultsma 07-01-2015 03:05 PM
I would like to know a little bit about merc #6 drives
having upper failures the most.
the boat weight is 9800 lbs dry
twin 1075's at 1175 hp a peace
41 saber
with big 6 blade props
1.5 gear ratio
having a hard time keeping drives in it now any advice or tricks to get more time outta them
oil recommended
maintenance schedule or tricks
didn't have one problem for a full season of hard running and now seems like a cant even get half a season outta them.
not name bashing or naming any names just wanna know more about #6 drives.
can I change gears to help or any tricks. thanks
skater40 07-05-2015 09:45 PM
call Vern at West Coast Drives 310-995-1670
turnerrd 07-06-2015 01:50 PM
Is this Jerry McConells old boat Clifford?
I would say it's the 6 blade props. Very hard on the drivetrain and in that set up the upper gears in a 6 would be the weakest point. Just went through the same thing with 700 Nxt set up. Merc said get rid of the 6 blades to make the transmissions and drives live.
41 saber
1.5 gear ratio
oil recommended
ICDEDPPL 07-06-2015 09:31 PM
How deep in the water the drives/props are and the 6 blades are going to be the big killers. High X and 6 blades are hard on drives. Drive guardians may help depending how much the boat comes out of the water.
Thebossbultsma 07-07-2015 07:31 AM
Yes this is Clifford. And that's what Russ was thinking about doing but just wanted to get a little more insite on it.
