-   -   Imco scx question (https://www.offshoreonly.com/forums/drives-lower-units/328078-imco-scx-question.html)
sl 07-04-2015 04:41 PM
Imco scx question
Need some help. Imco scx's - shut one engine down with drive in gear. Couldn't get drive out of gear. When I got back in disconnected outdrive shift cable from shift linkage. I can get neutral and reverse by manually moving cable but no forward. Can't get any cable movement for forward. Any help/suggestions would be greatly appreciated.
Tinkerer 07-04-2015 10:24 PM
Did you try turning the prop while moving the shift cable? Try turning the prop while you shift it. Unless the drive is damaged it should go into either gear while you turn the prop..
sl 07-05-2015 10:05 AM
Tinkerer I did try to spin it and still can't get forward. Thanks for the feedback!
Griff 07-05-2015 12:49 PM
Bypass the neutral safety switch and start it in gear and see if you can move it after running.
Tinkerer 07-05-2015 06:28 PM
Tell me You didn't force it into neutral when it was stuck - IF you did you may have bent the shifting fork. GOOD LUCK
Steve
253 07-08-2015 08:43 AM
If you forced it could have damaged the shift linkage or broke a set screw holding the linkage
sl 07-08-2015 10:01 AM
Tinkerer, Griff & 253 thanks for your help. Removed drive and it's on it's way back to IMCO. Should know next week what happened.
253 07-09-2015 11:12 PM
Curious what the problem is, please let us know when you get a report from IMCO
Milam11 05-30-2023 11:08 PM
Update?
Hey I know this is a super old post but what needed up being the issue? Having the same exact issue
