Changing props on bravo 1
I'm trying to change for bravo 1 prop to hydromotive. What am i missing to make this right?
Bravo 1 http://i699.photobucket.com/albums/v...psoa4y4vyx.jpg http://i699.photobucket.com/albums/v...psivodlqbc.jpg Hydromotive http://i699.photobucket.com/albums/v...psieojnhol.jpg http://i699.photobucket.com/albums/v...pskbwidsqs.jpg |
You install thrust hub?
theres a different style nut/lock tab/washer you need for that setup.
http://i52.tinypic.com/hweo79.jpg |
You also need the Thrust Hub to seat the prop on the taper of the shaft. Give Hydromotive a call, they will hook you up.
Hydromotive Engineering, LLC 9261 Ravenna Road, Bldg. B-1 Twinsburg, Ohio 44087 Phone: 330.425.4266/3629 Fax: 330.425.4394 |
after calling hydromotive they said i need a hub kit for a mirage prop??? does that seem correct?
Yup, for a pre Flo torque hub, the pressed in kind. You shouldn't need the thrust hub or prop nut if you already have those. Basically you need the spline washer depicted in the diagram above
| All times are GMT -5. The time now is 09:43 AM. |
