-   -   Max Machine Tower - Drive Spacer required??? (https://www.offshoreonly.com/forums/drives-lower-units/330220-max-machine-tower-drive-spacer-required.html)
fantastixvoyage 08-28-2015 06:20 PM
Just pulled off a 2" spacer to try a higher x and seems the Max tower in my upper protrudes down at least a 1/4" which is not allowing the lower to fully install. A stock upper is flush. What am I missing??? Do I have to run at least a 1/2" spacer? Seems odd
Tinkerer 08-28-2015 08:13 PM
Did you use the stock coupling between the upper and lower?
articfriends 08-28-2015 11:37 PM
Heres the deal- the Max worx tower uses a locknut on the bottom with a oring on it that measures EXACTLY .250 thick which is exactly how thick the spacer/collar in a stock lower is (this piece is REMOVED from a stock lower to bolt it on). SO, to install a drive spacer you need to machine the top of it to fit the tower nut they added and shorten the aluminum center piece that everyone uses in a space then you need to add a stock collar/spacer to lower. To remove a spacer that must have been modified as I mentioned you will need to remove the oring and .250 spacer around the verticle shaft to allow drive to sit into it properly, Smitty
fantastixvoyage 08-29-2015 12:24 AM
Thanks Smitty. I'm actually taking the spacer off so it sounds like there is a piece I can remove from the stock lower. I did notice they each had an outer o-ring. So the one on the lower just pulls or screws off?
sutphen 30 08-29-2015 07:04 AM
one on the lower wiggles straight out.
