strange noise
Old 09-14-2015 | 06:52 AM
  #31
I agree with Griff, post your solution !
Several members have taken the time to respond, so you in turn should post what your solution was !
This web site is worthless unless you do your part , then many others will do a search on the same problem and fix their problem with minimal effort.
Boating in the high performance area is extremely costly, and unless you are a millionaire, most people on here do their own work , that is why this web site is so great !
Big Boys Toys is offline
Old 09-14-2015 | 07:15 AM
  #32
Originally Posted by Tinkerer
Did you ever check to see if the alignment tool was parallel to the bottom of the boat?
Depending on transom angle this is not necessarily true. The alignment is checked to ensure the relation of the engine to the transom assembly and gimbal bearing is correct.
Unlimited jd is offline
Old 09-14-2015 | 08:13 AM
  #33
donzi matt's Avatar
I had what may be the similar noise on my 32 regal with Bravo 3's. Warming it up at 1500 RPM's, with the drives turned, I could hear a rattling/knocking noise. Took it to my dealer, they replaced u-joints, gimble bearing, the noise was still there after they essentially threw parts at the problem (both of those items were less than 2 years old). Took it to another dealer, they knew the issue almost immediately. They removed the drive, verified alignment was on, greased the input shaft and replaced the two rubber o-rings on the input shaft. The service manager advised me the noise would probably be gone for 2 years or so. He was exactly right. The boat was silent for at least two years before it crept back in.
donzi matt is offline
Old 09-14-2015 | 08:24 PM
  #34
Tinkerer's Avatar
With the majority of boats it is true. The U joints have to be inline.
Tinkerer is offline
