#6 wet sump u joint spicer part #
Any one have the spicer part # for the u joint on a wet sump #6 outdrive
Originally Posted by dennis r
(Post 4357307)
I have a u-joint in my shop will get the number for you, Not sure its a spicer but you can cross the number. |
just talked to spicer about their U joints for Marine apps FWIW spicer told me none as they got out selling U joints for the marine end and really not to use what they are recommended for the auto world..
I would call their tech line and verify if the same holds true. Their exact words were not enough volume to even warrant selling U Joints for marine apps. |
Spicer 5-188X U-Joint 1480 Series
This is what you need marine or not will work the same. Same as a dry sump. On ebay cheep. |
The early number VIs ran a Spicer 5-1410X we just did a set on some early flat top number VIs
Originally Posted by Team Archer
(Post 4360680)
