I would be interested in a pair if you could figure out the reverse rotation, have no desire to have reverse rotation engine,
sorry
i had a total brainfart on post 80. trs reverses rotation in the lower with gear on carrier instead of in nose. alpha 1 gen 2 reverses rotation in lower by simply running in reverse but the carrier is shorter. |
Hello SlowRyd. I pm you yesterday. I want to shorten my
Bravo lower and I wanted to talk to you about Getting a deep enough weld. And cutting down the vertical shaft. I want to run my drive on surface. Taken out 4" to do so. |
Originally Posted by scsmike
(Post 4510269)
Konrad 540. Much stronger upper and very similar to the Bravo lower
SlowRyd, what is the dimension you are looking for from the input shaft C/L to the prop shaft C/L?
Yea, that's an awesome effort, but considering I still blew a TRS upper after about 150 hours with 600hp (lowers only lasted 60-80), whereas my Konrad went 430 hours before the lower went (and I'm guessing that's cause I only changed the gear oil twice in 7 years). For me, anything over 550hp will never be in front of a bravo, TRS, or any combo of the two - just no damn fun.
Stay under that 550 or so and this is a great way to get more speed out of a TRS setup, for sure. |
It sounds great ,would be alot easier than raising motor and drive on my 23 Daytona no room,,in my 4 inches below bottom,how would a 5 blade cleaver work on a stock trs? 330 Hp,soon to have more. Nice job Ryd
ever figure out how to get it to work with twins?
Only option is a cam change to reverse the engine
I would be inttested in one
Final product. Randy it all summer long without a single issue. I tore it down over the winter for inspection and everything looked great. Also added a nose cone to maybe see if a little more speed. http://i584.photobucket.com/albums/s...316_164635.jpg
Looks great
Originally Posted by SlowRyd
(Post 4538389)
What rpm are you turning and speed? What prop size? I am interested if you decide to build more. Please keep me posted and safe boating! |
Originally Posted by Biggus
(Post 4511389)
(Post 4526813)
http://i584.photobucket.com/albums/s...330_181129.jpg
http://i584.photobucket.com/albums/s...330_181129.jpg http://i584.photobucket.com/albums/s...330_181129.jpg Haven't had a chance to compare speeds yet. But it has turned a 31 B1 6300 |
Originally Posted by WaveCrusher810
(Post 4542177)
would it be possible to shorten a trs lower to benefit the x dimension? I get that you wouldn't gain any durability but at least performance would be improved.
(Post 4542401)
Im sure that is possible just not 100% sure the -4.750 depth is possible. But it can definitely be shortened
any amount would be an improvement even just a couple inches. Would you be willing to take on a project like that or do you know anyone who could? PM if you would like. |
That is so impressive! Nice work!!
(Post 4542177)
Yes I can shorten a pair of trs lowers but like dereknkathy said I would have to completely retool to do so.
reversing the rotation. yes, you can reverse the engine rotation and turn the borg pump plate to run with it. can a TRS upper run backwards? and the bearing carrier side gear is the reason the right trs lower is the weak link. they made gen 2 alphas like that basically running them in reverse with reverse shimmed up a little better. they never put over 310 hp in front of them them though. there is a whole lot of twin small block gen 1 alpha boats out there. running both props the same way doesn't feel noticeably different. at least not at the speeds most older twin TRS boats are used to seeing. I don't see how two props turning the same way would be a real deal breaker for most peple.
Nice
Im almost ready to put my 23 in ,im 3 years behind u,wen u had it without the had steering ,is that why. It was poor handling,or was it the trs. Gearcase,did the nosecone help the trs? Thanks
The gearcase took care of the ill handling issues. The rams made it more stable in the rough water. I wouldn't run a nose cone on a trs lower because of such a low prop shaft depth
I gotta ask,why,cut the water with a sharp tool not a dull one,thanks
Originally Posted by tripps
(Post 4565945)
that's a good explanation 6.
made me think of this, about 30 seconds |
(Post 4565945)
As usual I'm late to this party but want to commend SlowRyd sharing a great display of American ingenuity and craftsmanship- cool stuff!
Gearcase
Yeah that thing is a beauty
hi. have you decided if you are going to crank some of these out for the general public, and a price and time frame to do these? or is this a hobby-one off? Ooh, just had a thought. Bravo 3 same case essentially. you could re-introduce the Blackhawk...sorta.
I would be willing to build these for people and they will be built on a case by case basis. I would project a 4 to 8 week build time depending on the build. Price will solely depend on options. Anyone that is interested feel free to pm me
Gearcase call me
(Post 4567229)
you do realize this is what konrad did. trs upper with bravo lower. used their own housings to update and marry the two.
Originally Posted by JIMG
(Post 4568547)
My application is same as yours 23 daytona trs. 9 below =slow
Call when u can it would be my best fix for my boat
Trs
Ok I give up going bravo how high can I go trs. Is 24 bravo is 22 fiberglass is anything how about 4 below center pod???
Sorry tripps. I just saw this. I will call you in the morning.
Reach out when you can , 985 774 1005
| All times are GMT -5. The time now is 01:55 AM. |
