It would not go into gear at all either direction. Friend reported that the boat was doing fine all day then went to leave a marina and had no control over the drive. When I got there to help we ran thru the usual so of coupler failure, broken shafts etc and nothing stuck out. We swapped the drive with a spare not touching anything else and the boat has been alive and well since. I'd like to see the clutch pix you have to compare. This was a higher hour drive so anything is possible.
Did you possibly shear the quarter inch socket head bolt connecting the shift fork to the shaft or the lower shift arm?
I feel better that it wasn't one that I sold you
I'm going to dive in further tomorrow when I get to my friends shop. I'll update with what I find
the very first simple test to do before tearing into it is see if the all the shifter assembly is working correctly. Take back cover off and shift the drive manual with some needle nose plyers front side of drive
then rotate propshaft to see if you go into gear and or rotate propshaft while manual shifting the outdrive. I would pull top cap off to see if you can see any damage / metal and or overheating as well did you have any impact damage related issues here ? Sometimes with SS props they look fine but the weak link is the internal drive components. you will need OEM special tools to completely tear the outdrive down and the correct service manual would be a very wise choice as well. I have all of that covered. Just saying |
1 Attachment(s)
Originally Posted by endeavor1
(Post 4385440)
Bottom, wasted clutch that would not engage in either direction until about 1500 RPM, and then WHAM, you were moving. [ATTACH=CONFIG]548881[/ATTACH] |
(Post 4385440)
Shouldn't you be out driving the Choo Choo train delivering packages LOL |
Originally Posted by Sydwayz
(Post 4385453)
Top, well used but fine operating clutch.
Since you said the oil is black you need to re torque the pinion bearings on the drive shaft ,
Update... Sleeve connecting the upper and lower shafts had cracked on bottom end. Guess when power applied it just spun vs grabbing. Never noticed till I split the upper and lower. Dumb me I guess. Never would have guess it was broke. Tore the vertical shaft splines pretty good. They weren't twisting though.
| All times are GMT -5. The time now is 12:44 AM. |
