-   -   Are XR drives more reliable now? (https://www.offshoreonly.com/forums/drives-lower-units/334696-xr-drives-more-reliable-now.html)
tgorbett 02-18-2016 05:44 PM
I have read on this forum that there have been lots of failures with XR drives in the past. Has this been resolved by Merc?
Are they more reliable than the X drive which is what I currently run. I am usually easy on drives but have suffered a failure with a Std bravo 1. Would like to move to a XR drive but only if they are more reliable. Thanks for the input.
Pol83x 02-18-2016 06:05 PM
Need more info. What are you running it on and what motor is turning it?
1 MAIDEN AMERICA 02-18-2016 06:33 PM
Theoretically it's stronger. Bigger shafts, bearings, cones and straight cut gears. The gears have been problematic with power but Bravo One gears would probably have the same issue.
indysupra 02-18-2016 06:44 PM
The b1/b1 x gears don't flake like the Xr gears. When the regular b1 gears break they don't take out the case either.
Wilks 02-18-2016 07:35 PM
B1x are 1/2 price of XR.
BUP 02-18-2016 07:45 PM
bravo 1 will not last in 500 hp and above - they are rated only rated up to 400 hp - bravo X does a better job but is rated up to 450 hp.
The best bravo made was 1993 & 1994. the gear material and its processing was better made by far.
I have had Bravo 1 's completely come apart including Bravo III's - non X and non XR's.
1989mach1 02-18-2016 07:56 PM
I have bravo 1x's behind my 500efi's in a kinda heavy boat. At 345 hours they were pulled apart when my motors where being done. Gears looks grate but the prop shaft that was on the same motor I blew a lifter in was not so good. Almost had to come back on one.
1989mach1 02-18-2016 07:59 PM
It is hard to justify the cost to go from the x to the xr for me
1989mach1 02-18-2016 08:03 PM
Gears at 345 hours
[IMG]http://i1149.photobucket.com/albums/...ps218d2c0f.jpg[/IMG]
Prop shaft that wasn't looking to good
[IMG]http://i1149.photobucket.com/albums/...ps535aaf55.jpg[/IMG]
tgorbett 02-19-2016 10:31 AM
That's an impressive twist!!
I seem to remember reports of excessive (define excessive) failures of the XR uppers. Anyone know if Merc addressed it?
525 hp in 4000 lb. boat single screw.
X has been reliable for me thus far but if I ever have a failure would probably consider moving to XR upper or lower depending on where the failure occurred.
JaayTeee 02-19-2016 12:41 PM
If the X is working for you, leave it alone
My experiences are that the only thing that they're addressed over the years is the price, 10 years ago an upper set was $ 1400, now there nearly $ 2k
