Picture of steel tower
Can someone post a picture of a steel tower? I've searched the forum and I can't find out how to tell if a case has the steel tower installed in it, or doesn't.
PM - Mr.Gadgets
I will.
Look down in case if you have a steel tower there are two hole opposite each other were a tool fits to unscrew the tower. When you looking down you will also see that the bottom of tower looks like a big circle, regular tower you see the aluminum at the base of tower, which is the case itself. I have a couple of them but can't post pic.
1 Attachment(s)
Here is a picture of what I have.
[ATTACH=CONFIG]551433[/ATTACH] |
That doesn't have a steel tower
Ok thanks- I thought it was just a standard B1
go to max machine worxs and down load their catalog - they have steel towers.
You can have steel towers installed in your drive, Mr. Gadgets would be more then happy to help you.
Originally Posted by kaama82
(Post 4407878)
Mr Gadgets put my towers in 4 years ago, I built the drives. I have not had a problem since.
My new Sportmasters are going there Saturday to be built!
Mr Gadgets dose fantastic work. Very anal about putting them together right the first time.
Great work, had him tower my B1 and set it all up. Very Happy!
Just an FYI- I took this upper to Mr. Gadgets to have him assemble it and the tower in this is a steel tower. It certainly isn't a stock tower, it is a steel tower.
| All times are GMT -5. The time now is 11:21 PM. |
