-   -   Bravo 1x Question (https://www.offshoreonly.com/forums/drives-lower-units/334873-bravo-1x-question.html)
mummaiv 02-24-2016 06:55 PM
Bravo 1x Question
Fairly new to me boat with B1x's with about 277 hours on them. Besides changing the drive oil, is there anything that should be done with this many hours?
JaayTeee 02-24-2016 07:42 PM
Torque the gimbal ring nuts, make sure the wear pads that contact the gimbal ring flanges are there, if it's a HP gimbal, check the hinge pin screws/bolts, if STD, take off the senders and check the hinge pins for being tight, check the bellows for any signs of cracking and if the oil comes out clean, don't worry about it
blownhammer2000 02-24-2016 09:07 PM
Sorry gotta be stupid and ask where in mechanicsburg? Only asking cause that's where I'm from too, not too many performance boats around here
BUP 02-24-2016 09:10 PM
pressure test outdrive per Merc specs after draining the gear oil - before filling with new gear oil.
mummaiv 02-25-2016 05:31 AM
Sent you a PM
pstorti 02-25-2016 02:20 PM
pull the drive off and have the alignment checked. Change zincs for the correct ones for freshwater if that is where it is being used.
