-   -   O-ring istallation procedures (https://www.offshoreonly.com/forums/drives-lower-units/336727-o-ring-istallation-procedures.html)
jpnova70 04-25-2016 07:53 AM
When installing the 3 O-rings on a Bravo lower unit (oil ,water, shift I think ,orange o-ring) Should you use Bellows adhesive on both sides before mating lower to upper?
Knot 4 Me 04-25-2016 08:06 AM
No. You glue the O-rings to the drive only. The compression of the rings against the bellhousing is what makes the seal.
jpnova70 04-25-2016 08:26 AM
Thanks for that.. The drive meaning the lower section right?
Knot 4 Me 04-25-2016 10:40 AM
Oops! didn't read your question as closely as I should have. I thought you were speaking of the O-rings that adhere to the upper portion of the drive between the drive and bellhousing that seal the shift linkage, gear lube feed, water inlet, etc.
jpnova70 04-25-2016 12:31 PM
I heard you just grease these up and install.. Hope the marina is right.
