-   -   What do you need to setup a LS engine to Bravo1 drive? (https://www.offshoreonly.com/forums/drives-lower-units/337085-what-do-you-need-setup-ls-engine-bravo1-drive.html)
GrannySShifting 05-05-2016 12:40 AM
Bellhousing same as SBC/BBC of course
hvymtl939 05-09-2016 11:03 AM
From what I understand, there really isn't anything involved, and they should just bolt up. Check out the LSX Powered Boats group on Facebook.
https://www.facebook.com/groups/1411850085808845/
Bondo 05-14-2016 09:37 AM
Ayuh,..... A cast iron flywheel, a Bravo coupler bolted to it, 'n the flywheel cover,.....
GrannySShifting 05-18-2016 01:09 AM
So your sayng a stock Camaro flywheel, and all the original stuff that bolted it to BBC and it all jives?
phughes69 05-18-2016 11:07 AM
I thought there was an issue with the crankshaft being a slightly different length too, or would that just pertain to an automotive transmission.
SB 05-18-2016 11:17 AM
There are a few LS swap threads in this forum. All you have to do is type LS into the search box and hit enter.
The last LS thread, which is still current, talks about alot of this stuff. Link: http://www.offshoreonly.com/forums/g...ls-engine.html
Members TimMoore and Corey331 speak a lot there and they both have LS's in their boats.
turbom700 05-19-2016 11:52 AM
Just got down (last week) bolting a bravo onto a LS, I used a manual flywheel, and the bolts lined up perfectly to the bravo coupler, I did have to drive the dowel pins out of the flywheel as they weren't in the correct spot. You have to grind the back side of the bravo bell housing down to clear the rear main bolts, they stick pass the bellhousing flange about .125"
That and you can only use 5 bolts not 6 to bolt it in. Not a big deal.
Here is mine in place.
http://i250.photobucket.com/albums/g...psm224nf5s.jpg
phughes69 05-21-2016 05:34 PM
Originally Posted by turbom700 (Post 4440863)
That thing is BAD A$$ looking. I like how you made the turbo risers.
Can you measure the width of the engine from outside of one exhaust manifold to the other. I'm contemplating a future project with twin LS engines where there use to be 4 cylinders and curious if the LS engines will fit without having to recut the transom to make the engine spacing bigger.
turbom700 05-22-2016 02:44 PM
Thanks I'm hoping it runs as good as it looks
28" outside to outside. If I remember correctly its a little narrow then a SBC.
