-   -   Rebuilt Drive - Bad "clunk" when going to neutral (https://www.offshoreonly.com/forums/drives-lower-units/341159-rebuilt-drive-bad-clunk-when-going-neutral.html)
Nuke427 09-12-2016 09:32 AM
So I had my starboard drive rebuilt, upper and lower since the lower gave way and sent metal all through the upper. Since I got it back, when shifting out of forward or reverse to neutral there is a bad clunk that vibrates the boat. Weird thing is it doesn't always do it, sometimes it's seamless like it should be. Any thoughts on this? I plan to take the boat in to have it checked out after I get some other things done on it but just throwing this out there to maybe gain some insights. Thanks!
No Coast 09-12-2016 11:20 AM
That is backwards from normal, usually the clunk is going into gear. Maybe check the propeller hub, I assume its a solid hub, maybe the rubber pieces have gone away. Really doesn't make any sense clunking out of gear.
Nuke427 09-12-2016 11:52 AM
Yeah I know, seems really weird to me too. It does clunk going in just like the port drive. But occasionally a major vibrating the boat clunk coming out. Very strange!!
Black Baja 09-12-2016 04:27 PM
Sounds like the gears weren't properly timed.
Nuke427 09-12-2016 04:58 PM
Guess I'll just have the Bravo Shop take a look at it before next season.. Thanks!
