-   -   Can I install X-R gears in a Bravo 1 X upper? (https://www.offshoreonly.com/forums/drives-lower-units/341471-can-i-install-x-r-gears-bravo-1-x-upper.html)
IRONMAN 09-24-2016 09:17 PM
A tooth broke off in my Bravo 1 X upper. Is it a good resolution to install X-R gears in the drive.? I hear they rob some speed on the top end?
Thx
sutphen 30 09-24-2016 09:27 PM
can you,,yes,,it depends on if your input yoke fits the xr gear,if not,them contact max machine worx for the right one.as for speeds,I really didn't notice any.
IRONMAN 09-24-2016 09:34 PM
Input yoke is an X style so I think it may be possible.
Griff 09-24-2016 11:20 PM
Can you = yes
Would I??? depends on how much HP you have. How many hours on the X gears???
XR upper gears wear out, chip, pit faster than X/XZ's.
An X is an XZ upper and regular bravo lower
An XZ is an X upper and XR lower
http://www.go-fast.com/mercruiser_bravo_sterndrives.htm
