Drive recommendation >
Old 12-08-2016 | 10:09 PM
Originally Posted by Panther
Had a customer two years ago with 700 hp in a 27' Fever. It had an SC drive on it. SC didn't hold up. Blew the upper and wasted the transom assembly at the same time.
I re-rigged him for a BMax 1.50 ratio. Boat didn't loose any speed and it's been two years since I did the job and no failures.
At the 700 hp level, you'll need to refresh the lowers every 3 seasons or so, depending how you drive it. Just change the oil every 10-15 hours and monitor the fluid. If you ever see a metal flake in the oil, keep a closer eye on it. If at the next 10-15 hour sevice there's more metal flake then the first time, it's time to tear the lower down and put a new gearset in.
I run 965HP on BMax HT's. My uppers were freshened after 300 hours with new pinion gears. The lowers I replace every other season. You gotta pay to play.... but I don't have any failures (knock on wood).
[ATTACH=CONFIG]562455[/ATTACH][ATTACH=CONFIG]562456[/ATTACH][ATTACH=CONFIG]562457[/ATTACH]
how many hours did the imco sc drive have on it behind that 700hp motor?
i have a 540 being built right now for a 27 ft boat with a fresh imco sc upper from imco all new gears ect. ect.
the -2imco lower i have with it, is said to be good to go but with unknown amount of hours...
will no hear in a few more weeks what the 540 goes on the dyno....
im actually second guessing my purchase of the imco sc....
chancer540 is offline
Old 12-14-2016 | 06:59 AM
Panther's Avatar
Frank's Marine Service
About 40hrs. I also had Imco SC's on my Apache years ago and would get about 20 hrs before one popped. That's why I went with BMax's and that was in 2007.
Panther is offline
Old 01-02-2017 | 09:10 PM
GPM
My brother replaced the SC with the SCX on his 26 DCB, he lost 20 mph and the boat handles like crap.
GPM is offline
Old 01-02-2017 | 11:18 PM
BUP
in 2007 that was the BMax out of Florida - correct ? So what changed currently for the BMax ? and the current offerings compared to the Florida based BMax ?
BUP is offline
Old 01-02-2017 | 11:19 PM
BUP
Probably too deep and wrong prop - and really he lost 20 mph ? if so that is a lot.
BUP is offline
Old 01-03-2017 | 01:32 AM
A good summary here.
http://midwestboatparty.com/forum/sh...ght=bravo+shop
Griff is offline
Old 01-03-2017 | 05:00 AM
GPM
-2 less than SC, same prop, -20 mph GPS verified.
GPM is offline
Old 01-03-2017 | 09:21 AM
There is always All American Drive Service, they will upgrade your Bravo and warranty it for 2 years and for half the price of an SCX or BMAX. Don't know of anyone else that does that.
ThisIsLivin is offline
Old 01-03-2017 | 02:57 PM
here is their "warranty"
** Two year Warranty is applicable on all stock horsepower applications and on selected custom build units up to 650 horsepower.
Boatally Insane is offline
Old 01-03-2017 | 04:02 PM
Panther's Avatar
I worked on a 28' Pantera this summer who had an SCX conversion done before I started working on it. The boat lost 11 mph.
The only was I was able to recover the lost speed was two part;
1. Swap out the SCX lower for a standard bravo lower and got back 8mph. I actually built and tested an SC lower and was still 5-6mph short. The standard Bravo lower was the only thing that worked on that boat.
2. Refreshed the engine and put a larger camshaft in it. That was good for getting him all his speed back plus an additional 2-3 mph.
Yes, that was the old Bravo shop.
There have been a lot of updates done by the new Bravo Shop which includes upgraded bearings, shiming proceedures, clutch stack height modifications etc. They also came out with a 1.50 ratio upper gearset which is probably the single biggest difference because the BMax drives I have only came with a 1.30 ratio back then. That change alone helped a lot with people no longer losing speed when making the change. The Fountain I did the conversion on had a 1.50 and he told me that he only lost 1 mph with the change. My Apache, even with the 1.30 only lost 1-2mph but gained 2-3 mph in cruise speed over the IMCO SC's.
Panther is offline
