-   -   How do you change the fluid in a #6 drive (https://www.offshoreonly.com/forums/drives-lower-units/345746-how-do-you-change-fluid-6-drive.html)
myfast70 03-27-2017 01:38 PM
I have not had any luck searching for a service manual or any luck with info on how to change the drive fluid in a #6 drive. Any help or links would be greatly appreciated!!
SFOcean 03-27-2017 10:37 PM
Might want to specify wet or dry sump. Dry sump has the swept back skeg.
Unlimited jd 03-27-2017 10:58 PM
My recent research has found the first early dry dumps were The old style skeg
ICDEDPPL 03-28-2017 12:05 AM
https://www.google.com/#q=1075sci+2+cycle+oil&*
6th one down is a PDF that covers the drive also..
mike38scarab 03-28-2017 09:03 AM
Give the Mercury Marine factory in Fond du Lac, WI a call. Just order the maintenance and parts manuals for the drive. All the info is in them. They are cheap and will save you time trying to lookup part numbers. (920)929-5000
Got Freedom? 03-28-2017 10:36 AM
If it s a dry sump #6 then you will need a special tool (91-847468T & 91-847418) to remove the nose cone and change the filter. The gear lube is pumped in through the bottom plug, just like a Bravo, but once it reaches the top hole you need to rotate the propshaft 80 times to fill the filter cavity. It doesn't matter which direction you turn it. Afterwards, re-check the fluid level and then put the plugs back in.
GF?
