IMCO lowers and water pressure
Who out there is running IMCO lower(s) and are you using pressure relief valves for your water pressure? Last year I ran sport masters and I didn't run pressure relief valves, but I've read that high water pressure can be an issue with IMCO lowers. If I need to run them, I'd rather plumb the boat for them while I have one of the engines out.
if you are planning on using a stock imco with a stock water pickup, you will have a hard time getting the water pressure to an acceptable level. your best bet is to weld up the stock pick up and drill a new pick up hole
One thing though - I didn't run all of the water through the exhaust. I dumped the water that used to go to the riser elbows out the back.This may have lowered the pressure.
My pressure was too high. After blowing 2 hoses. I installed a mechanical water pressure gauge, pressure relief valve and dump it out next to bilge dump. Standard length lower. If you run in any shallow water it will vacuum the bottom with the low water pick up. I am thinking about putting the stock lower back on mine.
Low to mid 80's
