Bravo Input shaft O-rings
Could someone please provide the part numbers and dimensions of the 3 o-rings on a bravo input shaft? Thanks.
The parts charts at mercruiserparts.com list sizes for most of the o-rings in the drives,
Genuine Mercury & Mercruiser parts. BRAVO ONE |
first making sure on the same page here as you - are you asking for O rings for when you re install the complete outdrive ?
If so, just buy the Bravo installation kit it comes with those O rings you are asking for and you do know you have to change the o rings gaskets on the bell housing to, when the drive is pulled ? the kit comes with all of that end to and is cheap in price - I have a ton of them. going off the top of my head Merc part number 16755Q1 hopefully I got it correct the part number. |
just a pic for reference
this O rings for the bravo input shaft ? http://coastalrides.co.uk/new-genuin...uj-input-shaft Have to ask why do you need the sizes of the O rings - Merc has the kit to buy with everything you need to reinstall the drive. There is more than 3 orings |
Thanks fellas, I have the kits; just wanted to verify the sizes w my mic. Appreciate the help.
While we're on the subject; Perfect Seal is what most people are using for the o-rings and do I want to do a very thin skim coat on the whole mating surface? I dont like the non definitive results I've been reading.. |
skim coat ? of what
clean surface on the bell housing for the O ring gaskets then bellows adhesive to hold them in place ( back side of Oring only)
. O rings on the input Yoke shaft you grease them and Merc Extreme grease on those splines but not on the tip. Just full length of splines with the grease |
Originally Posted by BUP
(Post 4564431)
(Post 4564427)
skim coat ? of what
I've got bigger issues now anyway... |
| All times are GMT -5. The time now is 02:51 PM. |
