Tranny slipping
Got boat out finally been sitting for 15 years,its a 23 cat w trs. And 330 Hp 454 ran 4900 rpm wit,slow, then went into netrul,then it moves until 2000 rpm then slips, looks like a 71 or 72 i no it has to come out ,any ideas ???
assuming you have a solid hub prop? If not maybe prop hub went south? I know it's kind of a stretch but worth checking before you pull engine & trans...
You didn't say, but did you change the trans fluid?
Tranny fluid will usually smell burned if their bad enough to be slipping. You sure it's a Borg-Warner trans and not a MercTrans. Should have a metal tag on it.
Is there a band to adjust too, or am I thinking of the merctrans? And is it just for reverse? You can download borg repair manuals free all over the web.
If you need new transmissions, I have a nice set of 72-C Green Tags with TRS tail stocks. Let me know if you're interested.
| All times are GMT -5. The time now is 02:20 AM. |
