-   -   add a -2 outdrive (https://www.offshoreonly.com/forums/drives-lower-units/348670-add-2-outdrive.html)
farmo83 07-24-2017 12:51 PM
add a -2 outdrive
So If I change to a -2 outdrive and change nothing else on the boat, do I need to go up a prop size? I can see it in theory as you have less drag, but I can see myself being wrong too. Boat is a Schiada RT if needed.
Tinkerer 07-24-2017 09:39 PM
If you are hitting the rev limiter now then yes. Otherwise No.
